Hi
I just replaced the plastic bushing and installed a rebuild kit for my left flipper in Medieval Madness (thank you pinballlife.com!). Everything went fine, but I now notice that the solenoid, mounted as it is between the two metal brackets, has a millimeter or so of back-and-forth play between those brackets.
Should I worry about it? If so, how do I make it tight -- a shim or something?
Thanks,
Brian
