(Topic ID: 5798)
Flipper rebuild question
By Dewey68
8 years ago
  • 8 posts
  • 6 Pinsiders participating
  • Latest reply 8 years ago by Atomicboy
#1 8 years ago
When do YOU decide on when it's time to rebuild your flippers? I'm considering rebuilding mine on my LW3 that I recently purchased, but not having played this pin in it's prime, I'm not sure that it needs it. I can make the ramp shot when timed correctly off the right flipper, and every once in a while a left-flipper shot will limp it's way up the ramp.
Any input is appreciated.
#2 8 years ago
if a backhand flipper shot makes it up the ramp, then you're probably ok. If you want more aggressive flippers, go for a slightly bigger coil.
#3 8 years ago
You should be able to send a well aimed and well hit ball to the extents of the pf. If you have a flipper that cannot generate the force needed to traverse the pf as intended (whether it be up a lane or ramp, etc), then the next step is to determine why. I may be limited to a dirty plunger, mushrooming sleeve, etc. I suppose if the game has a lot of miles on it, you might "want" to rebuild the whole thing...but generally there will be only a subset of rebuild parts necessary to get it swinging as it should.
#4 8 years ago
I take mine apart and look at the plunger and coil stop. If there is any mushrooming then I rebuild them. If you do a rebuild, don't forget to replace the playfield bushing too as they are not in the kits.
#5 8 years ago
Quoted from SealClubber:
It's amazing that only the DE/sega early kits have bushings, yet all come with new EOS.
As soon as I get a game. Always replace bushing and sleeve. If the plunger doesn't even remotely look new (tapered slightly at the end), I replace at least that and the link. If the coil *stop* (edit) is even slightly ill formed, replace that too. I will see if the spring, either type, looks good as well.
I keep all used parts for fixer uppers down the road, and for extra parts in a pinch, or to give to my other pinball friends at Christmas.
If it is a high end game, I don't even think twice, I replace the pawl/plunger, sleeve, bushing, bat, spring, clean the plate and clean the EOS. EOS switches rarely need replacing, unless then are broken.
Don't f around with flippers. They are the single greatest thing that makes a game "feel" good. Even if you are hitting ramps, you will notice a difference, and likely the bats are misaligned.
#6 8 years ago
Quoted from Dewey68:
OK, but its OT. I LOVE your default pic! (and a big tongue out to you, GFLM!!!!) lol
#7 8 years ago
Looks like a flipper rebuild kit is in order! ;P
Thanks guys
#8 8 years ago
Quoted from Atomicboy:
If the coil is even slightly ill formed
Meant coil *stop*, sorry. Coils are rarely replaced, only if you can't get a sleeve in there smoothly anymore, likely due to a previous locked on flipper.
Professor Pinball
$ 9.99
West Chicago, IL
2,300 (OBO)
Hanover, VA
PinSound
