By chattering, do you mean they chatter when you're trying to hold the flipper in the up position?
Flippers not having power makes me think they're not wired correctly. Once again, solenoid power goes to the solder tab with the thicker wire attached to it. Center tap (from the flipper buttons) goes to the solder tab with the smaller wire attached to it. Wires to the EOS switch go from the center solder tab and also from the center tap (thinner wire) tab. The EOS should open just as the plunger contacts the coil stop.
Make sure your flipper button switches are clean and adjusted well. Those tend to get pitted and dirty and can cause power issues also.
