(Topic ID: 193963)
Flipper Question - Left Flipper Up
By delt31
6 years ago
  • 14 posts
  • 6 Pinsiders participating
  • Latest reply 6 years ago by delt31
    #1 6 years ago
    I've read around about this so not in total dark but wanted your thoughts. Bally 1995 (Indy 500).
    Left flipper stays up after I press the flipper button. It continues after being turned off so mechanical. I think what's happening is I can feel a click towards the end of the rod going into the coil and at that moment, the flipper mech gets stuck until I push the bottom of the mech up (which essentially lifts the end of the flipper bat that is tightened in between to stay in place) and it no longer gets caught.
    As someone who won't be able to further troubleshoot until tonight, I would like to put an order in now to replace. WHat do you think is the issue?
    #2 6 years ago
    Quoted from delt31:
    Return spring, sleeve, plunger, coil stop, and/or possibly the coil if it overheated and expanded at some point.
    #3 6 years ago
    Quoted from ForceFlow:
    It can also be catching on the EOS switch.
    #4 6 years ago
    I thought we had this issue fixed. That spring stretched out might need to be replaced. Or the coil stop might need built out a little.
    #5 6 years ago
    Unfortunately it still occurs. When you say built out, what do you mean? As for the EOS I see that when I move the mech part of it hits that but I think it's intentional as it cause it to close/enact.
    Took the spring off too and the click I feel happens with it off too
    #6 6 years ago
    As cheap as kits are just rebuild both of them and they will be good for years.
    #7 6 years ago
    Quoted from delt31:
    If the plunger and coil stop have been worn down, that could cause the plunger to move further than it was intended and might not be able to move back by itself. Or, the plunger and or coil stop could have become magnetized somehow.
    If you haven't done a rebuild on your flipper mechs, it is a good idea to do so.
    #8 6 years ago
    Ok thanks guys.
    #9 6 years ago
    Quoted from GRUMPY:
    That's exactly what it was. I went through everything and the flipper was really strong. Knew it was something else and the eos switch would rub against the flipper pawl when fully pressed. After some adjusting, it's perfect now. Very strong thanks.
    #10 6 years ago
    Quoted from delt31:
    Not really. Coil stop is worn, plunger is worn. Allowing more travel, hence the pawl getting stuck on the EOS blade.
    Time to rebuild your flippers.
    #11 6 years ago
    what I've noticed is that the blade itself (the length of it) the pawl hit it as expected. This allows the EOS switch to close. However pawl continues to move past the EOS blade which is resulting it in getting stuck. It's working now but you think I should replace coil stop and plunger anyway? I ask b/c the flipper works and is strong. That being said, it's not expensive!
    Just want to make sure I understand.
    EDIT I just bought the parts and will update just to be safe.
    #12 6 years ago
    Quoted from delt31:
    New coil stops, new coil sleeves, new plunger assemblies, new EOS switches.The bushing the flipper shaft goes through the playfield in, it wouldn't hurt to replace them either.
    #14 6 years ago
    thanks - ordered.
    This page was printed from https://pinside.com/pinball/forum/topic/flipper-question-left-flipper-up and we tried optimising it for printing. Some page elements may have been deliberately hidden.
