Hello all,
I have owned a Chicago Coin Hee Haw machine for years. It is working quite well but there is a minor issue I'd like to fix. One flipper works fine but the other flips fine and has the right amount of power but unlike the good side, when you hold the button down, there is a noticeable buzzing sound. I know this can be common.
I just replaced the coil with one identical to the one on the good side and it made no difference. I see that there is a set of points that get opened mechanically when the flipper is held in the up position and I adjusted them to work the same as the good side. With the table up, I could feel it was generating a lot of heat which will probably burn out the coil pretty quickly.
Any suggestions on what I might be able to do to solve this? I also apologize in advance for any errors in terminology.
