Classic problem with no fix yet.
When you turn on my Elvis 2004 the bottom right flipper would fire and stay charged till fuse blows. So I replaced Q 16, made sure coil and diod are good.
Now I turn on machine, flipper coil does not fire or stay charged and fuse is good. But will not work during play or diagnostic test. I did run a wire from ground and then touched Q 16 and coil does fire!
Diagnostics says replace IO board or Replace CPU board? Not ready for that yet without a fight. Any help is much appreciated.
Thank you,
McPin54
