New! Dark mode!
(Topic ID: 210448)
Flipper on space invaders machine
By Burdett1600
2 years ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by Burdett1600
#1 2 years ago
The left flipper on my space invaders machine has gone crazy. When I hold down the flipper button the flipper will chatter or do a rapid fire motion and will continue to do this till I let go. Has the coil gone bad or is there something I could do to stop this from happening.
#2 2 years ago
Sounds like a coil issue. Visually inspect it and look at the copper wires that go to the lugs. Is one broken?
#3 2 years ago
No connections seem to be broken.
#4 2 years ago
I should add that this machine has been used all day and just now started having a problem.
#5 2 years ago
Replace the coil and report back
#6 2 years ago
The high resistance part of the coil is broken, could be a broken wire or coil problem. Check the thin wires soldered to the coil. Sometime one breaks off the solder lug.
#7 2 years ago
some times when the coil wire break is internal (not at lugs) you can see the sparking thru the coil wrapper if it is dark enough
machine gunning flipper = bad coil most of the time
#8 2 years ago
Alright a new coil fixed the chattering flipper thanks for the help everybody.
Third Coast Pinball
$ 49.99
PinballElectronics.com
$ 22.50
$ 84.95
$ 9.00
Cabinet Parts
Third Coast Pinball
$ 119.95
Allteksystems
Third Coast Pinball
$ 90.00
