I have a monopoly machine where the upper right flipper has stopped working. I checked the coil and it was working fine, it just doesn't work when the button is pressed. I presume this is an EOS issue. The thing I am struggling with is that there seems to be two EOS's Stacked on top of each other with a plastic piece in between the two EOS's. If I replace the EOS's what about that plastic piece? Do I even need it?
