Hey guys, having a problem with my upper right flipper on STTNG. It stopped working, so I raised the playfield to take a look. When I press and hold the right flipper button, the lower right flipper works fine. As for the upper, I can hear a slight buzz coming from it, and see the mech on the upper right flipper move just a smidge, but not enough to move the flipper. If I move the UR flipper into the up position by hand (while holding the flipper button) it stays up, as if the "hold" coil is working.
From what I have read, I think if the power stroke coil were bad, the UR flipper wouldn't move at all when I press the flipper and probably wouldn't make the faint buzz... is it possible I have a bad diode, causing the "hold" coil to always be the one firing even when the power stroke one is supposed to?
