Trying to remove flippers from Gottlieb system one dragon assuming they just pull off is that correct?
Not sure by what you mean by just pulling off. Under the playfield where the flipper coils are, there should be a pawl with two screws - they bite into the shaft of the flipper. Loosen both of those screws - if not sure, you can take them all the way out. When the shaft is loose (The flipper should move freely without moving the pawl) then you can lift the flipper straight out.
Sometimes the flipper shaft will have burs from the screws and will drag on the pawl - so there may be a LITTLE bit of resistance when pulling up on the flipper.
I have removed to Allen screws and it won’t slide through, is this something that is able to be tapped on through or is there any other suggestions? Thanks
You removed the wrong 2 Allen screws. You see the part that the spring is connected to, it moves with the flipper. Look inside that piece for the 2 Allen screws.
Yes I have taken out those two Allen screws in there I also was going to replace the coil sleeve it is gross. After you remove those two Allen screws is that black post supposed to slide directly through it went about a half inch And stopped. I do appreciate any help this is the first machine I have ever attempted to do any repairs on
Quoted from bifjohnson:is that black post supposed to slide directly through it went about a half inch And stopped.
It will get stuck from burrs on the shaft from the allen screws, so twist the flipper in a circle while pulling upward and it will slowly pull thru the metal paw and plastic bushing. Be careful not to hit yourself when it comes loose.
This page was printed from https://pinside.com/pinball/forum/topic/flipper-help-3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
