New! Dark mode!
(Topic ID: 155905)
Flipper gets stuck in up position (Stern, AC/DC)
By scp
  • 10 posts
  • 9 Pinsiders participating
  • Latest reply 4 years ago by surfsled
#1 4 years ago
Hey all. My AC/DC Luci has been working just fine, but lately the right flipper has been getting stuck in the "up" position. Usually for no more than a few seconds, and definitely not on every flip. Any ideas on how to fix this?
#2 4 years ago
If you turn the game off does it go down, or does it require something to hit the flipper like a ball. If you turn it off and it goes down, I would suspect switch on the flipper, if its binding, I would suggest a flipper rebuild, or at least pull the flipper apart and see what is creating the bind. As I would not suspect a flipper rebuild would be necessary unless you have played 10K plus game on it. However, some parts can always fail prematurely.
#3 4 years ago
Things it could be:
* Coil sleeve is worn and sticky
* Plunger tip is mushroomed and dragging
* Coil stop is magnetized
* Return spring is deformed/detached
Maybe a few other things, too.
#4 4 years ago
The most common cause of this is the eos switch rubbing on the white part that activates it causing it to sort of jam up until it vibrates back down. You'll need to raise the playfield and move the flipper bat with your hand and see. It could also be the flipper button sticking. Or any of the things stevevt mentioned which would indicate for flipper rebuild
#5 4 years ago
It could definitley be a number of things. But I had this happen on my acdc not too long ago. Mine was a bad coil stop. When the stop gets loose, it tears up the brass and then the stop touches the steel bracket and completes a magnetic circuit so the plunger sticks to the stop. The giveaway for me was there was lots of shiny brass dust under the flipper mech inside the cabinet. If you see a bunch of this shiny brass dust, you know that's the problem.
#6 4 years ago
Okay, so not knowing what much of this means, how would you describe a good way of troubleshooting this? What do the parts I'm looking for look like? (Wish I was better at this... Thanks in advance)
#7 4 years ago
If you don't know what much above means I would buck up and find a local pinball tech to repair. I wouldn't mess up a 7k machine.
#9 4 years ago
Almost 99% that your coil stop is broke. Very common on stern flippers. Just get a 5/16 nutdriver and take off the coil stop. Youll notice thay the round piece is loose .it is supppsed to be welded. Being loose causes the flipper to get stuck.
$ 24.95
New Gloucester, ME
