I'm stumped. I've rebuilt flippers more times than I can count, and for better or worse, haven't come across this issue.
On my recently acquired Twilight Zone, I rebuilt the flippers with new coil stops, sleeves, and plunger/links because I noticed the left flipper wasn't as strong. Starting up the game, everything is great. Flippers are strong and I can make shots no problem.
However, after just a few minutes (it seems this is taking shorter and shorter time to occur), the left primary flipper gets weaker and weaker until it merely flutters. The coil is hot to the touch, as in, holding your fingers on it would burn your hand. The right flipper (which performs just fine), is warm but nothing noteworthy.
The flipper moves smoothly by hand, with proper play. I checked the EOS switch and even used a business card to remove what very little grime was present. Switch levels show the EOS is getting tripped.
I don't get it.
