I havent had a ton of time to troubleshoot yet, but here is my problem:
Upper right flipper on TAF is intermittent.
Lower right flipper is fast, solid, and strong.
If I hold in the flipper button, the lower right flipper actuates and holds. The upper right flutters up and down.
It just started today.
Obvious thing is that this morning I repaired the EOS switch on the lower right. I was getting an error from it and noticed one of the wires had totally separated from it so I resoldered it.
Any thoughts? Any ideas where to check?
I should hopefully have some time tomorrow after work to check into it and throw a meter on some of the wires to test...
