We're back!
After a disaster in our datacenter took down our server, we are now running Pinside on a brand new server. However, things may not work as expected as we are still polishing the playfield and adjusting some switches! We might be switching to maintenance mode a few times. Please see this forum topic for more info.
(Topic ID: 237315)
Flipper firing repeatedly, won't stay up...
By yyyyyikes
2 years ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 2 years ago by knockerlover
#1 2 years ago
Hi all.....
Just going back after years to my Centaur.
The right flipper fiires, and if you hold the flipper button down it drops and fires repeatedly.
Is this just a coil problem, i.e. is the low voltage coil part not holding the flipper up?
Should I just swap the coil over? All solder points and switches seem to be operating corrently.
Thanks in advance....also....
#2 2 years ago
Maybe the wire on coil.
Make sure the coil wire itself is solid on each lug. Also power wires are solid
Good luck
#3 2 years ago
I'd say coil issue.
If swap coils to see if that makes a difference.
If you are in need of early ss coil let me know part number and I should have one cheap if you're interested
#4 2 years ago
Thanks McPin, I had some spares stashed away somewhere, replaced it and it works.
Cheers for the support....now if only I could get someone to help me with a Say it Again lead....
#5 2 years ago
I recently ran into a similar issue on a data east machine. It turned out that the end of stroke switch was opening, and disengaging the high power.. but because a lead was broken off the capacitor the low power (hold) side was never engaging.
I would test the diodes on the low power side of the coil, and inspect all wiring connections.
