(Topic ID: 288263)
Flipper Creep
By robey99
1 year ago
  • 10 posts
  • 10 Pinsiders participating
  • Latest reply 1 year ago by Seamlesswall
    #1 1 year ago
    My left flipper on my CFTBL keeps moving up every time I play which makes the game unplayable. I have the nut so tight that I am about to break off the head. InactualltbThe flipper mechanism is brand new. Should I wrap the metal with some tape and try that. Any ideas? Should I replace the mechanism. Thanks.
    #2 1 year ago
    Crank harder - I've only ever broken one bolt. Or new pawl - yours might not close enough over the shaft.
    #3 1 year ago
    Sorry, this image is the first thing I though of when I read flipper creep...
    #4 1 year ago
    Could be a broken flipper bat. I had a similar problem a few years back on my MB. The plastic to metal was slipping so that the pressure of hitting the ball caused the bat to rotate.
    #5 1 year ago
    This is what I thought of when I read flipper creeping up the playfield.
    #6 1 year ago
    Is the flipper bat new, so that the shaft is round? A worn flat spot on the shaft will want to rotate to that point.
    Also, isn't a flipper creep that one really weird dude always hanging around pinball shows wearing a trench coat?
    #7 1 year ago
    Quoted from robey99:
    Replace the flipper pawl (the piece that grips the flipper shaft.) with a new one.
    #8 1 year ago
    You can also align it correctly and tighten it down enough to leave a mark from the screw then take it back apart and use a file to make a flat spot where the screw grips then put it back together.
    #9 1 year ago
    If none of the tips above work or you didn’t want to try, switch flippers...move right to left and left to right.
    #10 1 year ago
    Someone mentioned to me once to scratch up with emory cloth the flipper shaft, obviously just where it meets with the clamp part not the whole shaft.
