I posted on RGP, but thought i'd keep this topic going here too in case someone isn't on or checking RGB.
My game was set at 5 degrees so I changed it to 7 degrees pitch. Helped a little, but not nearly enough.
I tested resistance on the coils and checked them against this chart https://www.flippers.com/coil-resistance.html
Not sure which combo of lugs i should use, but I measured the orange wire (first lug to the second lug and then first lug to the third lug.)
for FL11629 I get readings of 139 (first to second lug) and 143 (first to third lug). Charts suggests it should be closer to 133. bad coil or diode(s)?
for fl15411, I am getting 137 and 142 compared to 150 suggested in the chart.
not sure what to look at next, if I've measured correctly or how to interpret what I'm seeing.
thanks for the help.
