Hi pin friends.
Did a flipper rebuild and upgrade on a taxi.
Long and short of it is, I soldered the wires back on the new updated coils backwards.
Guess I blew the coils, as they did not work.
So I install the old coils again to make sure that the new ones were toast, and still not working.
So I check the fuses in the backbox, and find that f6 J12 fuse had blown.
Put in the new fuse and almost, .....
Only the left flipper is working.
Re-solder the wires again on the right coil, just to make sure a good connection was made. Still not firing.
Triple check that the wires were back to the proper posts, and all is correct.
Same as the picture that I took before I started the job.
Is there another fuse for the right side?
Am I missing something here?
Getting tired so Im heading to bed now, and will hopefully have better luck with a fresh start tomorrow.
Still very new at this, so hoping for a bit of guidance please.
Thanks for the help.
Jeff
