Hi All-
I have three pins from the 1976-1978 era (2 EM 1 SS, 1 ea Gottlieb, WIlliams, Bally), and I have a question because I am now starting to notice that there are certain characteristics to my games, one of which slightly irritates me
This question is very specific to the following situation.
A) Hold a flipper button down
B) Leave the button depressed and let the ball hit the extended flipper near the tip of the flipper
Results for Gottlieb and Bally-
Flipper basically does not move ball bounces off a little depending on how fast its going.
Results for Williams (1976 Grand Prix)
Flipper retreats 1/16 inch or less and immediately closes EOS switch so flipper rebounds and ball is flung upwards (not hard, but it makes it 4-5 inches up the play field).
I have COMPLETELY mechanically rebuilt the flippers on the Williams (there are no original parts but for the metal assembly bracket that holds everything (note- the COILS have been replaced previously but not be me). The flippers function very very well in game play, they are nearly dead silent on a hold open, I have the EOS switch as TIGHT as I can possibly make it without the flippers buzzing when held open. What I mean to say, is if I move the EOS gap any tighter whatsoever the switch never really gets held open and it arcs across causing the coil to rapidly cycle high/low power and the flippers to vibrate a tiny bit.
So, to me, I dont see how to make this any better, I am not even sure its a problem. But what kinda make me think it is... is the fact that the gottleib and Bally mechanisms are basically identical and do NOT suffer this problem and its not like their EOS switches are gapped any tighter.
In thinking about this, its not totally clear to me how one might engineer a fix (even if its designed to operate this way)... basically, the flipper rotates, the arm hits the EOS switch and its open or its closed. The flippers are AC coils in ALL my games. So once the switch opens the high current winding is taken out and the coil is quiet and the flippers are held up... but in the Williams game, its almost like the low current (small diamater) wire in the coil is somehow too small and the hold up current is just weak enough that the flipper can quite easily be moved backwards just a tiny tiny bit by a ball (NOT a fast ball, just a normal average ball speed).
So- either I need to relace my coils (they test fine by resistance and are wired correctly- this would NOT happen if they were reversed)
OR- this is actually whats SUPPOSED to happen and its part of the game play. Its not like holding a flipper open and letting the ball run into it is a very useful trap but occasionally I do this intentionally and I am penalized for doing so on the WIlliams game. It could very well be the case the designers did this to keep me from playing this way (they also put big holes in the side lanes so you cannot trap balls by live catcing and letting the ball run back up the side lanes)...
Can someone inform me if it SHOULD play this way... I have never seen another Grand Prix (its hardly rare but its not like many arcades have these (none in my state I am aware of))....
Cause if its definately NOT supposed to do this, I clearly have a set of coils with too many windings in the lower power wire or too small diamater on the wire, because I cannot think of any other possible way this would happen.
