(Topic ID: 120139)
Flipper bottom right
By PjM
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by PjM
#1 4 years ago
My bottom right flipper in WH2O will not work until about 4-5 games played, then it works fine. Upper flipper works fine all the time. What do you think it is or how/why does it self correct after several games? Thanks.
#2 4 years ago
I'd start by going to switch edge test and slowly push the flipper button in to see if both optos work.
Or swap left and right flipper button opto boards to see if the problem moves.
Start eliminating things.
LTG : )™
#3 4 years ago
That problem sounds crazy, but you can definitely cut the problem in half by diagnosing it as switch problem or coil problem via the test modes.
#4 4 years ago
Thanks to both of you. I did the test and it functioned normally and now is all good.
$ 159.99
5,200 (Firm)
Newtown, CT
