Remember also that the existing indentations in the shaft will often **find** the setscrew tip and return the flipper to the wrong position.
Sometimes the only fix is a new shaft.
Quoted from vid1900:
Swapping the left and right flipper shafts usually provides a fresh place for *one* of the screws to bite into. The other one may line up half-way with the old indention and want to pull it into there with the screw point, so for that one you can install a flat-tipped screw and just let it bite the half of the post that's there.
But I agree, replacing is the best option. Just MAKE ABSOLUTELY SURE the flipper is in the correct position before cranking down the screws and putting a divot in the flipper shaft. It's pretty much impossible to fine tune that position with pre-existing divots in the shaft.
Yup I have two brand new shafts, that's why I'm asking The old ones were pretty chewed up.
That's why sometimes I need to grind that area of the flipper shaft of any previous bite marks from the set screws. It usually works pretty well. If not, then a new flipper bat is in order.
This seems to happen to me every. single. time. What a PITA!
Quoted from V_piscopo:
How are those new flippers?
I don't know what to tell ya... How are they not?
Lining up flippers seems to be a real toughie. Well, I find it difficult and probably 70% of games I have bought do not ever seem to have flippers lined up properly and matching each other.
I usually get it right by a ton of trial and error and still not sure the best way of getting each flipper the same as with set screws loose. line them up in up position?
Clamp a straight piece of wood to the flipper (with new rubber installed) , align it with the lane guide, tighten the flipper pawl.
That's actually what I ended up doing last night. My set screws have cupped ends, not pointed, to they definitely wanted to "walk" as I tightened them down.
Quoted from polyacanthus:
You get a second shot by flipping left and right...
If its off by a small amount you can adjust the stop in or out to correct.
Fwiw
This has been discussed before and I believe there weren't any hard facts re settings, but people were 50/50 on it.
