I recently bought a #flipflop that worked fairly well. I replaced one coil and sleeve early on (upper left flipper). Then the lower left flipper EOS switch broke (brittle). After I replaced that switch, I noticed that flipping the flippers on the left side of the machine immediately kills button control of all flippers and lights "Game Over"
If I disconnect the left upper flipper, the game will play with the remaining three. Would love some advice on how to fix this issue.
I also have 3 out of 4 Flip Flags working. Flag No.3 (second from the right) is unresponsive. The rollover buttons won't flip it or trigger a chime. Same with the red target in front of Flag No.3. If I manually flip the flag to the flipped position, the game counts it as a flipped flag and the rollover buttons and target will trigger the chime once again.
Maybe unrelated, but I thought I would include both issues here in case there is a correlation. Thanks for your advice.
