(Topic ID: 187173)
Tech: Flintstones (WPC) Right Flippers Stay Energized
By rogerdodger
5 years ago
  • 7 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by R67en
#1 5 years ago
Hi Guys:
Both the upper and lower flipper on the right hand side of the playfield are energizing and staying energized, as soon as the game is powered up, before even starting a game. I know, from past experience, that any solenoid that is constantly energized is often the result of a failed transistor.
I put my analog meter across the middle leg and the left leg of each transistor and transistor numbers 4 and 8 (reading down from the top on the attached pic) are reading 2 ohms but all the other transistors read 60 ohms. I then retested putting one lead on the middle leg and the other lead on the right leg of each transistor and got the same results. Does this mean that these 2 transistors are bad?
I swapped a board from another game and all OK, so I know this board is the problem.
The board is a PinLED Fliptronics board. I e-mailed them to request a schematic but received no reply. I can't read schematics anyway!!
Any help appreciated
Roger
#2 5 years ago
I'd go into switch edge test and see if both optos on the right hand flipper button opto board work.
#3 5 years ago
Quoted from LTG:
Switch edge tests work fine..... and board from another game works perfect, so it is clearly a board problem.
#4 5 years ago
Replace the transistors that tested bad.
#5 5 years ago
Quoted from pintechev:
So my basic test confirms that those 2 transistors are bad?
#6 5 years ago
Quoted from rogerdodger:
Confirmation anyone?
4 years later
#7 1 year ago
rogerdodger I know this is an ancient thread, but I'm having the same issues. I just did board work on the MPU, and now my flippers lock on immediately. Not sure where to start. Happen to remember how you resolved this?
Arcade Upkeep
$ 99.00
Arcade Upkeep
$ 18.95
KAHR.US Circuits
$ 159.99
