New! Dark mode!
(Topic ID: 73232)
Flintstones - Williams - Question about "the machine"
By MurphyPeoples
6 years ago
  • 33 posts
  • 9 Pinsiders participating
  • Latest reply 6 years ago by thewolks
There have been 10 images uploaded to this topic. (View topic image gallery).
#1 6 years ago
Hey folks. I'm cleaning up (turning into a "rebuild") a Flintstones for my daughters Christmas. I'm finishing up with cleaning the machine and putting the new rubbers on. I have a question about the two posts in the middle that hold the plastics circle.
They are indented like they should have rubbers across them too. Should they? The picture I saw on IPDB didn't have any, and mine didn't but if they don't the balls hit the metal posts. I was thinking they should at least have the rubber sleeves like the ones that go around the circle.
Can someone help answer this? Thanks in advance.
Murphy
#2 6 years ago
I am fully shopping mine out right now and have it all torn down to the playfield, so I have lots of before pictures, can you post or PM me a picture of the concerned area and I can check all my before pictures and send you some as well. Thanks Jonathan
#3 6 years ago
Mine has none, don't think there is enough room for any.
#4 6 years ago
Mine has 2 rubber o rings from post to post.
#5 6 years ago
Like pinbum... mine has the 2 o rings as well. Great pin, and great Xmas gift too!~SpOoKy
#6 6 years ago
Here is a shot from the IPDB (it's too cold for me to want to walk out to the shop right now).
Notice the Two pins below the plastic in the center. They are indented to take rubber o-rings. But this clean looking example has no rings either.
For you two that have rings between these two posts, how does it play with them there? Kinda naturally I assume?
Thanks so very much for the responses. I was worried that FS had no love.
Murph
#7 6 years ago
Plays fine. And FS has much love! Look up the owners club thread here that Blondetall started. Mods upon mods, good info and more. Have fun!~SpOoKy
#8 6 years ago
Mine does not have rubber (mine's like the one in the photo)...
#9 6 years ago
Quoted from MurphyPeoples:
Murph
Here is a shot of mine during tear down, mine has the two rubbers around them
machine-585.jpg 34 KB
#10 6 years ago
You can sort of tell from this photo, but I put two black post sleeves on my rock crusher.
#11 6 years ago
I also recommend adding a few spotlights.
I have one pointing at Joe's Dinner billboard, one at Bowl-A-Rama and one behind/under Dino crane pointing at the business guys.
The spots definitely brightened up the game....as did the Dino crane LED mod.
#12 6 years ago
Pics of my spotlights and an underside pic of how simple it is to attach the spotlights with some insulated alligator clips from Radio Shack.image-106.jpgimage-36.jpgimage-768.jpgimage.jpg
#13 6 years ago
I also used a half inch spacer on the spotlight pointed towards Joe's Diner to get a better angle and not have light reflect off the playfield glass.
#14 6 years ago
Quoted from Ranhorton:
Very Nice and thank you for the PM info..
#15 6 years ago
Great Stuff! I'm going to add the rubbers rings today and finish that corner of the playfield. It's the first area I started working on and I've given myself a week to get this pin cleaned up. I went through the underside of the playfield last week and corrected many missing parts, burned out bulbs, etc. This is one dirty pin. It has black dust everywhere and I have to believe it's NEVER been cleaned up around the upper playfield.
But it's cleaning up nicely. I'll post a few pics later tomorrow. Thanks again for the replies. I'll try to hunt down the flintstone thread mentioned too!
Oh wait... one last thing. How does the alternative playfield sticker hold up to play? The one I've got (and yet to put on) looks very well done/high end. But I worry about how it would look down the road.
#16 6 years ago
Look at a flier back page, is shows no rubber rings on "machine" spinner.
#17 6 years ago
I have done 5 of these machines. Three have had the rubber on them, one has had rubber post sleeves on it and one has had nothing.
Sean
#18 6 years ago
Somebody get Trudeau on the phone!!
I'm going to have to argue that the picture on the flyer is wrong. (believe it or not) And that Post sleeves would be wrong too. Without rings there, the ball hits a lock nut, and I just can't see Trudeau designing it that way.
Why would the two center posts HAVE indents for the rings if they weren't meant to be there? Not trying to be argumentative. What a fun game though!
I'm taking the dive into the bowling alley this weekend. I'm going to replace the pins with new fresh ones. Say a prayer for me guys!
#19 6 years ago
I have the post sleeves and the ball(s) have never gotten stuck once.
And good luck with the bowling alley pins. I had to re-cut the metal flapper on mine.
Luckily it's just ramp steel and i had a roll of if it. But I had to borrow a buddies riveter to attach the new flap.
Oh, and if anyone's bowling pins tend to pop out from a ricochet or errant ball, I discovered a great way to keep it from falling off.
Find a thin, small washer and cut a slice into it. Then you can wedge it under the "T" section on top of the pin so it won't slip through.
#20 6 years ago
Holy Crap! I didn't think it was going to be this involved. Now I'm wishing someone designed replaced Mylar'd decals.
#21 6 years ago
Yours probably won't be so bad.
I replaced my pins with new ones when I tore down the whole playfield after picking up the game.
I had to replace the metal flap on mine because it was broken. If yours isn't then changing the pins should take a few minutes. And I had to use the washer trick because on of my slots the bowling pin fits through was a bit worn and the pin "T" head wasn't as wide as it could be.
Mine was probably a worse case scenario.
#22 6 years ago
The pins are no problem at all, they come right out and will go right back in, they have laminate stickers for them.
#23 6 years ago
1 more day gents. Can't wait!
#24 6 years ago
Thanks guys! I'll be digging into it in the morning. Quick break to run some toys down to the Newberry Boys Farm down the road after lunch, then back on it before dinner. I really appreciate all the help.
#25 6 years ago
The Pin replacement was a breeze. I just hope I can get it all back together this weekend! LOL
Ramps, switches, rails, etc all came off. Unbelievable how dirty this game was, but it's cleaning up beautifully.
At the rate I'm going I'll be happy to get the left side of the playfield cleaned and put back together.
Question. The machine screws which hold the switches onto the ramps. One of mine was stripped out and isn't going to go back in. Where Can I buy the screws and threaded backing plate? I'm going to put it back together with one, but it's easy to get to later down the road. I want to replace it before my daughters play it at Christmas.
#26 6 years ago
Use a small nut if you're talking about the one that goes through the playfield into the plate underneath.
#27 6 years ago
Here are shots of how dirty it's been. All the under playfield inserts are covered in black along with all the bulbs. You can see the ones I've cleaned off, versus the ones under them that I haven't. And also the upper lanes before I've touched any of that. But again, it's cleaning up nicely.
#28 6 years ago
Quoted from thewolks:
Nah, it's the ULTRA SMALL machine screws that connect the ball switches on the ramps and rails. They run through the switch and the screw into a threaded backing plate to hold the switches above the ramps.
#29 6 years ago
I finally got Flintstones up and running well. Only two minor switch issues that do not effect game play. One question - I made "the machine" during multiball.... is the machine supposed to run the entire time of multi ball? It felt that way.
Also - Does it sometimes take as long as a minute for a ball to come out of it???
#30 6 years ago
I believe it does run the whole time during multi-ball.
And it can hold on to the ball for what seems like forever. However, it's supposed to stop to let the ball drop if it hasn't after approximately 10 seconds.
#31 6 years ago
gotcha. I will check Machine times once the Christmas unveiling happens. If there's a problem with long spin times, I'm going to bet it's a switch. I only got two faults when I finished servicing the game, and one was the Machine entrance switch. Which I chalked up to it being VERY loose up and down. So that when the ball comes through it, the arm actually moves up and over the ball, and doesn't "click" as the ball enters the machine. that must activate a timer. No problem replacing it though. But I just don't have time before Christmas.
The nice thing for me, is that I actually drive right by Marco Pinball in Columbia every Friday during work. So I stop in there and pester them once a week for little niggily part issues, which they are always able to help with! I am SPOILED. It's like having your own pinball parts department right in the neighborhood. It's my local hardware store!
#32 6 years ago
It's definitely your switch to the machine causing it to keep spinning if the ball doesn't find the exit. The machine doesn't know it's in there.
Easy fix.
And jealous that you don't have to pay for parts shipping whenever you need something in a pinch!
#33 6 years ago
Easy fix.
I agree, I had 3 orders in 2 weeks, as I kept finding more needs, got hit with that shipping each time, so I generally buy more than I need to try and justify the freight??
$ 9.95
$ 37.50
$ 47.00
