I am having some problems with my Flinstones.
Here is the Switch Matrix I am having problems with.
The items marked red do not work properly.
The items marked green on same row work fine.
Is it possible to have a faulty u-19 that 5 of the 7 switches work?
The 2 single targets do nothing. The middle of the 3 bank target does not register when knocked down so they do not pop up.
D rollover target at top does not register.
Ball popper sometimes works and sometimes does not. But on machine startup it pops 4 or 5 times.
I have cleaned the opto's and resoldered the popper connections. Checked all switches for shorts. I have continuity on the white/blue wire all the way from the bottom of chain to the plug J209-7. Taking out the CPU board and checked solder connections and possible bad tracks looks like new. Tracks ok.
It did work when I first got the machine and developed this fault. After 2 days the fault went away now it has reared it's ugly head.
Any suggestions as I am completely stumped.
