New! Dark mode!
(Topic ID: 147116)
Flinstones Motor Problems
By surfsled
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 4 years ago by LTG
#1 4 years ago
I had my motor go out on the machine on location. It would not work in test nor in gameplay. I put a pinball rubber across it so the balls would not get stuck in the play. Then after a month it started working normally again. I was glad I didn't order a new mech from marcos for $80. Has anyone had this happen? I check the wires to the motor, the transistor is fine in the back box, the motor control board seems fine (nothing broken off), the motor voltage tested fine.
#2 4 years ago
Might have a dead field on the motor. If it stops on it, it won't start.
Hopefully keeps going for you.
LTG : )™
Arcade Upkeep
$ 229.99
