I've been fixing up a Flight 2000 for awhile and I am almost done but I have a reset issue going on which I believed to be caused by the drop target wiring. I think that because when some of the drop targets are activated at the same time the game will reset. Or if the drop targets are down from a previous game, and you press the start button, the game will restart as well. Most of the time it is caused by Drop targets numbered 3 and 5. Occasionally 1 will cause it to reset as well. I swapped out the diodes but that didn't fix it. I also went to replace the switches since the switches in it were not original. I could not find the switch number in the manual so I had to get something that looked similar but that is causing the same thing. I looked on all my usual parts suppliers and none of them knew what the "correct" switch was but Marco told me to order 180-5104-01 but not sure how to wire that one up since its a different style than the two other switches I have tried. Here is a picture of the first switches I have tried that didn't work and the one not screwed down is the newest switches that I need help wiring in to try.
https://www.marcospecialties.com/pinball-parts/180-5104-01
20201005_122745 (resized).jpg20201005_122757 (resized).jpg20201005_122806 (resized).jpg20201005_122819 (resized).jpg
