hello Friends,
I have a Flight2000 i picked up semi non working that had been in a family home for 25yrs, very clean pf, bg, plastics, underside, etc. really worth restoring!
It was blowing the fuse onthe rectifier/ps (the main power fuse after the transformer) whenever the molex bundle that goes to the pf was in. I assumed it was shoddy wiring to a replacement coil etc.
Cant locate anything obvious. i purchased a Rottwndog replqcement board. This is where my dilemna started.
The existing board has all wires from the transformer soldered directly into its back trace points. ive never seen this on any pin. the new board only has the 3 molex connectors. i am hoping someone can confirm if this wiring was a hack, and likely the reason for blowing. the back of the old board is in ba shape now, likely due to heat.
This cant be right is it? pics of old and finally new below:
