Hello fellow Pinsiders. I recently picked up a non working Flight 2000. Cabinet, backglass, and playfield all in pretty good shape I got it pretty cheap and would love to get it running again. When you power it up the GI lights work, and there is a small ball of light on all the displays. The led on the mpu does not flash when turned on. I tested all the fuses and they are fine. I have been using flipperwinkels guide for Repairing Bally Electronic Pinball Games from 1977 to 1985, Part One to test what voltages my boards should have.
Power Transformer Module (Rectifier board):
TP1 = +6.5 vdc (AS2518-49 version, feature lamps) Im getting +6.03
TP2 = +230 vdc (score displays) I am getting +254
TP3 = +11.9 vdc (+5 regulated) I am getting +14.2
TP4 = 7.3 vac (general illumination) I am getting 7.13
TP5 = +43 vdc (solenoid voltage) I am getting 45.8
GND = Ground
Solenoid Driver/Voltage Regulator board:
TP1 = +5 vdc I am getting -.487
TP2 = +190 vdc I am getting +164.7
TP3 = +5 vdc I am getting -.487
TP4 = +230 vdc I am getting +256
TP5 = +11.9 vdc I am getting +31.5 (this voltage drops into the negatives (-120)when the mpu is plugged in)
MPU board:
TP1 = +5 vdc I am getting -.421
TP2 = +11.9 vdc I am getting -103.8
TP3 = +21.5 vdc (comes from +43 vdc solenoid voltage) I am getting +22.4
TP4 = Ground
TP5 = +5 vdc I am getting -.421
I`m not getting my 5 volts at all, and also some other funky voltages. I`m a newbie when it comes to a pinball not working at all, hoping someone could look at the voltages and steer me in the right direction of what to look at next or what to concentrate on (MPU, voltage regulator)
