(Topic ID: 318272)
Flight 2000 - intermittent solenoid power issues
By mof
1 year ago
  • 22 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by mof
#1 1 year ago
SYMPTOM
Sometimes I lose power or get partial power to flippers and/or the two maze kickers -- I don't think I've seen the pops, drops, or the slings lose power even once. It's happened off and on pretty much since I got the game. I can go 10 games with no issues, then the problem comes back. I can turn it off a while, then on again (didn't count the time interval to imagine heat changes) and then it might work fine again for a few games.
OTHER WEIRDNESS
kinda loud hum in attract mode *before* you start a game after first power up.
WHAT I'VE DONE
* reflowed SDU-100 header pins
* added 3 grounding mods to back of SDU-100
* verified solenoid fuse and under-playfield fuse have continuity out of socket (replaced playfield fuse for good measure)
* tried jiggling all 5 SDU female connectors while flipping flipper that is dead (no change) -- but only tried this once
* Disassembled both maze kickers and cleaned em.
* swapped in another SDU-100 to verify that the problem in fact goes away (which at least eliminates female connectors + other boards and fuse clips)
WHAT I HAVE NOT DONE
* measured TPs while in a good or bad state
REFERENCE
https://www.pinwiki.com/wiki/index.php?title=Bally/Stern
http://techniek.flipperwinkel.nl/ballyss/rep/index1.htm
https://pinside.com/pinball/forum/topic/vids-guide-quick-bally-driver-board-repair-bulletproofing/
READING
https://pinside.com/pinball/forum/topic/stern-pinball-troubleshooting
https://pinside.com/pinball/forum/topic/flippers-dying-mid-game
https://pinside.com/pinball/forum/topic/strikes-and-spares-solenoid-power
https://pinside.com/pinball/forum/topic/bally%E2%80%99s-hotdoggin-solenoid-issues
https://pinside.com/pinball/forum/topic/how-to-test-flipper-relay-on-solenoid-board-ballystern
https://pinside.com/pinball/forum/topic/classic-bally-flippers-not-working-stumped
https://pinside.com/pinball/forum/topic/bally-eight-ball-outhole-kicker-not-working
https://pinside.com/pinball/forum/topic/stern-meteor-flippers
#2 1 year ago
Here's an example of the maze kickers working on partial power. Both kickers were disassembled and cleaned to eliminate drag as part of the issue. And again, it's an intermittent power issue not friction/drag.
#3 1 year ago
I had had this issue many moons ago on a classic Bally and I ended up replacing the driver board with a Rottendog and it fixed it right up!
If you wish to keep the original then I don’t know what you’ll need to do
#4 1 year ago
Did you try reflowing the solder joints on the flipper enable coil?
Have you tried disassembling the two maze kickers, cleaning/replacing the sleeves? How do you know it is for sure a power problem and not a physical problem? Im not sure if they share any wiring, but maybe there's frayed wire(s) on the maze kickers.
Are these problems directly linked? You don't have the flipper problem independent of the maze kicker problem, or vice versa?
#5 1 year ago
Quoted from Knxwledge:
They tend to go together.
Yes I cleaned the maze kickerss. (Added above)
Did not touch the flipper enable coil -- which is what?
#6 1 year ago
Quoted from mof:
Oops I meant relay not coil. I would try disconnecting the maze kicker coils and see if the flipper still has problems
#7 1 year ago
I'll swap SDB's and reflow the relay and report back.
I can't help but wonder about the clue where kickers/flippers go low power -- but not the drops/pops/slings. Wouldn't that point to something?
#8 1 year ago
Re flowed flipper relay. No change.
I can get power loss 3 minutes into playing a first game.
What do the two kickers and flippers have in common that the other solenoids do not?
#9 1 year ago
Swapped in a new sdb. Sure seems like that's the case.
Cannot reproduce error now after 30 minutes of play.
Interesting that the loud hum is still there in attract mode.
What's a possible next step for troubleshooting the old sdb?
#10 1 year ago
I'm looking in the user manual -- what is the difference between "momentary solenoids" and "continuous solenoids" ? -- it appears I am just having intermittent low power issues with the continuous solenoids.
#11 1 year ago
Quoted from mof:
I think flipper solenoids are momentary and coin door lockout coils are continuous.
#12 1 year ago
A friend gave me a hint. Check for good ground. I cleaned up pins 23, 24 with an eraser -- on j3. I'm 10 minutes in, so far so good. Fingers crossed.
#13 1 year ago
Quoted from mof:
A friend gave me a hint. Check for good ground. I cleaned up pins 23, 24 on j3. I'm 10 minutes in, so far so good. Fingers crossed.
Perhaps run a jumper wire from the blue-white wire from the the rectifier board to its connection on the the flipper solenoid and make sure nothing is going on with that power wire.
#14 1 year ago
That's a wrap. J3 male pins up for re-pin someday...
#15 1 year ago
For the hum, replace the 1000uF filter cap on the SB-300 and use a high quality cap, preferably closer to 2200 - 4700uF. The connector pins must be in good shape too. The ground return wires, ones goes the transformer and one goes to the driver board. When the returns to the driver board go bad (orange wire!) it can start to get some ground loop hum. The "ground mods" on the driver board should help too if that is what is going on.
I was using Panasonic ECA-M series as the 12v bulk SB-300 filter and they cleaned up all the hum in the Stern SB-300. When I ran out of the Panasonic caps I bought and and swapped to a Nichicon UVR series @ 1000uF. First batch I tested all had a pretty nasty 12v hum. Putting a 2200uF UVR series instead cleaned it up all the hum.... just something to keep in mind.
For the flippers and some coils cutting out. I would honestly monitor the 43v bus wire. I ~think~ the flippers power bus shares a wire with other coils on the playfield. If the voltage is dropping out when the coils stop working, look for a frayed bus wire daisy chained around the PF. Might be holding on by a single thread somewhere.
#16 1 year ago
I think I have a backup set of new caps here from big daddy I can swap out.
Which set would you start with? I prefer to change things one at a time rather than shotgun all 5. I have a chance to find cause easier, and learn more that way.
#17 1 year ago
It's funny as far as hum goes, this is my only B/S with hum.
I have hum in 66% of my sys11s + sys9:
Diner, Taxi, Grand Lizard, High Speed, Space Station, and Sorcerer. (but NOT in WW, Pinbot, Space Shuttle)
#18 1 year ago
oops I replaced the 5v ripple cap on the sdu-100 haha. funny stuff. Still good to do!
One sec! I think I have the sound kit too...
#19 1 year ago
Looks like the previous owner took care of it? Or are those originals...
20220709_f2k-sound-board-caps (resized).jpg20220709_f2k-sound-board-caps (resized).jpg
https://www.bigdaddy-enterprises.com/repairkits/stern_kits.htm#SB-300
#20 1 year ago
I'll open a new thread for it someday when I choose to chase it down. I think the game is playing a tone and it's low and sounds like a hum -- there are certain parts while playing when things get quiet, and I hear the low hum tone again, and then it's gone rest of the game. I don't think it's just pure line hum. But that's just me guessing.
#21 1 year ago
Quoted from mof:
Try to temp put another 1000uF across the 12v on the SB300. It will probably clear the hum out.
Those caps look like just your super basic general purpose caps which may not be good enough at 1000uF to eat up the hum.
#22 1 year ago
thanks for the cool idea -- I need to make a movie for you, so you can decide whether it's a tone or a hum. I'm leaning towards a tone at this point.
$ 125.00
Melbourne Beach, FL
$ 12.00
$ 3.00
Cabinet Parts
20eyes
arcade-cabinets.com
Crown Point, IN
$ 12.00
Third Coast Pinball
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/flight-2000-intermittent-power-issues and we tried optimising it for printing. Some page elements may have been deliberately hidden.
