(Topic ID: 266520)
Flashers not working, pls help!
By Corey_Fleming
1 year ago
  • 8 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by pintechev
#1 1 year ago
Hi guys,
On my SMB pinball machine all the flash lamps work in the headbox, but none of them work on the playfield! Any ideas? They aren't dead.
#2 1 year ago
Which transistor(s) control them and is that transistor working?
#3 1 year ago
I fixed it and it's working now, yes it was a transistor. But then I turned it on and it blew the playfield illumination fuse, I replaced it and it blew again, I'm afraid it'll catch fire or something if I try again. The fuses are the right voltage so I dunno what the problem is...
#4 1 year ago
Fuses typically blow due to shorts. I would carefully examine all of your wiring and see if something is shorting out. Also - pull the GI connectors from the boards and see if the fuse blows, if it does, you have a board issue. If it doesn't, you have a wiring issue.
#5 1 year ago
Which board controls fuses? (I'm a pinball noob)
#6 1 year ago
I am not familiar with Gottlieb; hopefully someone else with experience can better guide you.
#8 1 year ago
Bump so you see this.
