Flasher on lotr stays on all the time. How do I troubleshoot this?
Remove the bulb, until you figure out what transistor drives it and replace the transistor that is shorted and keeping the flasher on.
Quoted from RussMyers:That's a nice advantage to LEDs - if they lock on, they don't melt stuff.
Exactly. One of the many benefits to LEDs!
(I think your problem with the melting dome would only look appropriate in the Williams machine, aptly titled 'Fire!').
Quoted from pinhacker71:I was putting a led in. There wasn't a bulb in there when I got it.
That's probably why the bulb was removed by the previous owner.
Find and test the associated drive transistor - probably shorted.
RM
I've got a soldering iron and a voltage meter. Now what? This will be my first attempt at this. Will the schematics tell me where to find the resistor? Can I get a replacement at RadioShack or must I order one? I'm ready to jump in. Biggest job I did before was replacing targets.
Quoted from pinhacker71:I've got a soldering iron and a voltage meter. Now what? This will be my first attempt at this. Will the schematics tell me where to find the resistor? Can I get a replacement at RadioShack or must I order one? I'm ready to jump in. Biggest job I did before was replacing targets.
Slow the heck down.
Learn the difference between resistor and transistor.
Get an old board and practice on.
When you are good at removing and replacing components then remove your board and fix it. Mark all connectors and pictures to get board back in right.
Your manual can tell you which transistor it is.
Ed will have the transistor http://www.greatplainselectronics.com/ I doubt Radio Shack will.
Quoted from pinhacker71:Flasher on lotr stays on all the time. How do I troubleshoot this?
Wow. I'm having the exact same issue on my LOTR right now! Need to figure this out myself.
Which flasher is it? On mine, its the one on the bottom right, near the flipper.
Quoted from RobT:Wow. I'm having the exact same issue on my LOTR right now! Need to figure this out myself.
I ran into that on a LOTR, was the IC upstream from the transistor doing it - if you run into one of those, socket it.
I've had this problem 2 times before. Once on Goldeneye and transistor replacement was the fix. The other was on TZ and for some reason, after I changed the incandescent flasher to LED, the problem went away and never returned (year and a half now). My guess is the lower power draw had something to do with the TZ fix and the transistor is still suspect. You can get the transistor number from the bulb matrix chart in the manual, if my memory serves correctly. Make sure you have good solder (makes a huge difference) a solder sucker and a decent soldering iron. The solder points on the transistor are small so, don't bridge them or lift your traces.
Quoted from LTG:socket it.
What are you referring to when you say this? I just like to know as my brain is a sponge on this great website. Always trying to learn.
Quoted from Jeff_PHX_AZ:What are you referring to when you say this? I just like to know as my brain is a sponge on this great website. Always trying to learn.
If you have to replace an integrated circuit that is soldered directly to the board, if it's one you may need to do again in the future - for instance a switch matrix one like an LM339. It is best to put a socket onto the board after removing the integrated circuit so you can just plug a new one in.
Integrated circuits have lots of legs, and removing and resoldering all of them increases the risk of damage to the board.
You don't do things for transistors and simple things.
If you have to replace the IC that is further upstream from that transistor.....Instead of soldering the new IC on the board, solder a socket to the board for that IC. Makes future repairs easier.
Quoted from pinhacker71:Same one lower right next to flipper on lotr.
Interesting, and Lloyd said he had this happen too. Appears to be a somewhat common issue on LOTR then?
Tested transistor and no 000 readings. Should I try to reflow solder. I'm really flying blind here. Places led flasher back in and it stays lit entire time, even while other inserts and gi are cycling. Don't know if that means anything.
Hi Ron. My brother-in law lives out near fletchers! You and him are perhaps neighbors!
My apology for the O.T. comment. We will take it private pm if there is more to talk about
Quoted from LTG:I'd replace the transistor first. Then the IC upstream from it next.
If he's not getting any zero readings why replace the transistor? I mean why bother reading it if you are still going to replace it? Just wondering, as I still have to diagnose my problem as well and I have yet to pick up a multi-meter.
My guess is he is saying that replacing the transistor is easier than the IC, so replace it just in case your test was bad first. I'd probably retest the transistor, then replace the IC, with a socket like suggested earlier.
Update. Wish I knew how add that to the thread. Sent email to Ed at Great Plains electronics and he responded quickly and was very helpful. Sent out transistor. I bought the 12.99 desolderer at the shack. Pulled board today and replaced transistor. Flasher now works. Thanks to all who helped me. It's exciting to be successful at my first board work. Now I can play and enjoy all the flasher goodness.
Quoted from pinhacker71:Update. Wish I knew how add that to the thread. Sent email to Ed at Great Plains electronics and he responded quickly and was very helpful. Sent out transistor. I bought the 12.99 desolderer at the shack. Pulled board today and replaced transistor. Flasher now works. Thanks to all who helped me. It's exciting to be successful at my first board work. Now I can play and enjoy all the flasher goodness.
Great! I lurked in this thread off and on. Glad you were able to get It fixed. I learned a lot as I followed along!
If you want to change the title of this thread, you should click edit on the first post of the thread.
Can you confirm which transistor it was on the board?
Quoted from RobT:Can you confirm which transistor it was on the board?
As an update to this thread, it was the transistor at Q14.
I tried to test it with my multimeter, but there were no 00 readings, just like Pinhacker said. Replaced Q14 anyway. It did the trick and my flasher works great!
As an aside: I swear that replacing this transistor also had a positive impact on the sound quality for some reason. Sounds are crisper and more clear than they were. Very strange.
Quoted from Crash:Drawing power from the sound board, limiting the high tones? No clue.
Yeah, no clue here either, but that makes as much sense as anything that I could think of I guess.
This page was printed from https://pinside.com/pinball/forum/topic/flasher-stays-on-melting-plastic-dome and we tried optimising it for printing. Some page elements may have been deliberately hidden.
