IJ left side flasher (#37) stays lit solid when any other flasher is on. Does this during gameplay and flasher test. All other flashers work and flash properly.
I've read through several threads, but want to confirm my approach to diagnosing the issue.
It's likely a transistor (per other threads). Based on schematics, I should starts with testing Q16 then possibly Q5.
What readings am I looking for on the multimeter?
Can I remove the flasher bulb for the time being and continue playing without risking further damage?
