New! Dark mode!
(Topic ID: 133718)
Flash Won't Boot
By troxel
5 years ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by troxel
#1 5 years ago
Recently got a Flash that would not boot. I have replaced sockets, 40-pin interboard connector, and all connectors on the cpu and driver board. Also installed new lamp matrix power resistors. Game just shows two solid LEDs. Put this on my bench so power should not be an issue. I burned Andre's test rom, but it's not doing anything in IC17.
Calling it a night, but wondering if anyone has any input on it.
#2 5 years ago
One thing I learned the hard way is that it won't boot unless the mpu board is connected to the driver board.
#3 5 years ago
Quoted from uncivil_engineer:
thats something i didn't know i thought you could test mpu board on the bench
and when it worked connect the driver board thanks for that info
#4 5 years ago
Have driver board connected to it. Doesn't leon's rom run with just the mpu? If so, where can I find the file for it?
#5 5 years ago
You do not need the driver board connected to run either Leon's or Andre's test ROM.
Leon's: http://www.pinwiki.com/wiki/index.php?title=Leon_Borre_Repairing_Williams_System_3-6_CPU_Boards
Andre's (better choice): https://pinside.com/pinball/forum/topic/wms-sys-3-7-andre-test-rom-usage-video-v2
Usage and link in the aforementioned thread.
viperrwk
#6 5 years ago
Switched out the cpu and now game is booting. Still messing around with the test rom on the bench and will report back with questions on it.
#7 5 years ago
I put the board back into the game, but didn't remember the PROM order (system 4 board). I rearranged them a couple times and finally got the game to come up. Now I am not able to coin up the game and start. Tried to put the game on free play (which it was) and the credit button isn't responding to adjustments. Put the game in 03 test to test switches and nothing registers.
Am I missing something obvious?
#8 5 years ago
Updated the roms to the greens version (along with soldering some bad solder joints) and now game is playing again. Will start the process of shopping this out. I know the drop targets will need quite a bit of attention, but looks like everything else played well.
1,400
Mount Pleasant, SC
$ 14.00
1,450
Blaine, TN
$ 12.00
Siegecraft Electronics
Bokchito, OK
$ 11.00
Professor Pinball
$ 259.99
$ 28.95
$ 209.99
