I can't find any detail on what AMP fuses go into this sound board. Any ideas?
Also, where do I locate the 6f2 and 6f3 Logic Supply main fuses? I'm a newbie at this and can't figure it out from the schematics.
You're asking about two completely different sets of fuses.
The sound board fuses are on the sound board itself, and are 4a slow blow. The sound board has its own integral power supply, and gets fed straight AC power without any fusing between it and the transformer
The logic supply fuses, 6F2 and 6F3 are on a separate fuse board that's below the power supply. They are the two right side fuses. Also 4a slow blow.
Quoted from HHaase:The logic supply fuses, 6F2 and 6F3 are on a separate fuse board that's below the power supply. They are the two right side fuses. Also 4a slow blow.
6F2 and 6F3....Right side fuses next to the sound board in the cabinet?
I think Hans was confusing Flash and Firepower.
On Flash, there is one fuse on the fusecard below the power supply. It is a 20A fuse for the GI. (The other two fuses in the right of the photo I added for the lamp and solenoid voltages.)
In the cabinet, there may be either one or two fuses on the sound board. These are 4ASB as Hans indicated.
To the right of the sound board, the unmarked fuse is another 4ASB (7F2) which protects the logic supply voltage to the sound board.
And lastly, to the right of that, there's the line fuse which is indicated in the photo (8A).
viperrwk
This page was printed from https://pinside.com/pinball/forum/topic/flash-williams-sound-board-6f2-and-6f3-fuses and we tried optimising it for printing. Some page elements may have been deliberately hidden.
