Hi everyone-
I'm slowly weeding out all of the gremlins in my Flash. In the recent weeks, I've done a LOT of fixes and upgrades to the game, but unfortunately I still can't get it to run stable. Here's a rundown of what I've done and where I'm at:
Upgrades/Repairs-
Rebuilt PSU with all new caps, diodes and 5v/12v pin header & connector (also dropped displays to 91v)
Rebuilt MPU- new rom, ram and cpu sockets. Installed new ram, cpu and freshly programmed green rom set. Replaced 40 way connector. Replaced all pin headers, replaced 5v/12v input connector. Replaced 5v regulator.
Rebuilt Driver- All pin headers replaced. 5v filter cap replaced. 5v and switch matrix connectors replaced. 40 way connector replaced. Lamp matrix upgraded to MOSFET drivers and 0ohm resistors
Sound board- (unrelated to resets but I'll list my fixes). New caps all around. New buffer IC's installed (previously played incorrect sound effects).
Current Problem Description / The game's current state-
The game will boot up perfectly 100% of the time. I am able to leave it in attract mode without crashes or resets. I am able to run all diagnostic tests with no crashes or resets. All sollenoids and switches fire properly from diagnostics. All lamps flash correctly both in attract and diagnostics mode. When I start a game, I can usually get through ball #1 just fine, sometimes not. Just about every single time, the game crashes on or around when I get to ball #2. When it crashes, it appears to be in two parts. First, the lamp matrix will start flashing every lamp on/off (just like diagnostics test), then after a while the lamps will all turn off and displays will go blank. When this happens, flippers slingshots and jet bumpers are still energized. I need to physically turn the machine off then back on to get it "running" again. It should also be noted that Leon's test rom passes all tests when bench booted with an auxillary PSU. Also, up until last night, there was (accidently) 35v DC running into Column #3 of the switch matrix. Is is possible it caused damage to my switch PIA where it still functions (until its under game-load and breaks down)?
Does anybody have any ideas on where to start poking around? It seems as though the game crashes when "under load" (during a game). I haven't isolated it to a specific sollenoid, switch or combination there of. It seems to crash at random.
Gut tells me to- check all coil diodes for shorts and suspect the switch matrix PIA. Would love to hear some other suggestions...
Thanks for any help guys
