Hi everyone-
I'm making good progress on the Flash that I'm rebuilding. I have gone through and upgraded the power supply, cpu and driver boards. All three received new pin headers, male/female interconnect, caps, various PSU upgrades and the 0ohm lamp matrix mosfet upgrade. The game is running pretty stable now, however I have a weird switch column problem that is stumping me.
All switches on column 3 (spinner, pop bumpers and a few roll overs) do not register with the CPU unless the flippers are engaged. This is both in the diagnostics and during gameplay. All three flippers have been rebuilt with nos switches and flipper coils. The cabinet switches have also been replaced.
I can't quite determine why the flippers would have any effect on ONLY this column (all others are fine). Where should I be suspecting the fault? IC17 on the driver (N7406), or IC11 (PIA)? Or is it potentially a connector issue? The switch matrix headers have been replaced, however I didn't replace the connector (yet). Or is it possible its unrelated to the switch matrix entirely (since the flippers impact them being detected). Maybe a diode issue in the switch row?
Is it possible I have something miswired under the PF? I removed the harness for clear coating over the summer, but I left all switches soldered to the harness. Only the coils were cut and resoldered, verified wiring against the manual (although it wouldn't hurt to double check).
Thanks for any tips, this one is really stumping me!
