Hey guys, having some trouble with my Flash project. It has been blowing F2 ( which measures 36.52vdc+ instead of 28v) (don't know if that matters). What's weird is it let me play for a couple games but not always_, and further more, in the middle of play (even after testing all switches and solenoids) it just starting going crazy. (Come to think of it, I haven't tested the replay knocker for shorts). After it goes amuck, I power it down and turn it on, and it still goes amuck. I cannot always start a game even after it sits for hours, most of the time it just starts flickering the display w/or without noise on power up.
Pretty vague I know, but usually that's how these things go.
What I know:
-On power up, it starts a game and all solenoids are active (unless powered by the blown F2) (i.e trough)
-1J2-9 reads 12v+, not 5v+ as stated in a driver board print out I got from ipdb - though it does say 12v+ in the schematic, so I'm confused on that.
-F2 reads 36.52v+ instead of 28v+
-All 5v+ pins read 5v+ except one above
-All 18v+ pin's read 18v+
-All 12V+ points read 12V+
-Under the hood there doesn't appear to be any broken or touching wires. There was a broken diode across the slam tilt, but I repaired that (prior to that repair, you could hear the tilt noise on start up..).
The board did suffer some damage from battery leakage, but it looks like it was repaired.
The video of startup:
