(Topic ID: 288908)
flash pinball wont boot
By Matthew2015
2 years ago
#1 2 years ago
just got a pinball has a project and was wondering what it means by the cpu board having two red lights that come on when it boots up.
IMG_3515 (resized).JPGIMG_3515 (resized).JPGIMG_3516 (resized).JPGIMG_3516 (resized).JPG
#2 2 years ago
Hi. Is the manual available? If not, a copy can be downloaded from here:
https://www.ipdb.org/files/871/Williams_1978_Flash_Manual_March_1979_no_schematics.pdf
Start on the lower half of page 22 for troubleshooting that LED sequence.
#3 2 years ago
okay , i looked over that and it said to check things on table 13 , but the only thing i am unsure about is what 3d6 and 3d7 are.
nexr , it says to remove driver board from cpu board which means all cables including the 40 pin connecter at the top?
#4 2 years ago
They are diodes on the power supply board.
Verify voltages are as shown on Table #4, manual page 21.
#5 2 years ago
...and the 40 pin connector is the interconnect between the CPU and Driver boards.
#6 2 years ago
are the 3d6 and 3d7 the diodes beside the power plugs from the transformer ? could not find power supply schematics in the manual.
#7 2 years ago
There is a separate manual with schematics and layouts. Stellar Wars & Flash use the same PS:
https://www.ipdb.org/files/2372/Williams_1979_Stellar_Wars_Schematics_February_1979_low_resolution_and_bleached_paginated.pdf
#8 2 years ago
measured 3J6 , there is 12+v unregulated output but no voltage on the 5 volt pins.
#9 2 years ago
okay i changed the fuse on f5 and it now show between 3 to 4 volts on the 3J6 vdc pins , but that not enough voltage is it?
#12 2 years ago
how do i measure the 5v transistor LM323K to see if its causing low voltage?
#13 2 years ago
i cleaned the connecters and it is getting 5v now but now showing no lights on the cpu board.
#14 2 years ago
okay now the 12+v unregulated is now 9 volts , so i think i will need to change the fuse holders and reflow solder joints because after getting a better look at it after taking it out , the fuse holders are rusted and solder joints look cracked or corroded.
#15 2 years ago
the 2 red leds came back on after testing the volts again which are normal (12v and 5v). it was the fuse clip that was causing the low voltage
i already took the driver board out and tested just the cpu board and it still shows the same 2 red leds locked on.
i think the only solution is get to get a new cpu board and driver board. Is the rottendog mpu327 any good? i cant find one in stock.
#16 2 years ago
the only other thing it could be is that there is a flipper coil where the wiring broke off the solder joints , would that cause the mpu not to boot?
#17 2 years ago
First thing to do is get that40 pin connector replaced on driver board and the cpu board.
#18 2 years ago
the voltages from the power board seem normal , it the cpu mpu that i cant find the problem with.
i tried it with the driver board removed and it still does not blink . i think its all the rusted ic chips and corroded solder joints on the board that are causing the problem but i just don't have the skills to replace ic chips.
i think i going to get a new mpu like the rottendog mpu 327. is it any good? been trying to find one in stock.
#19 2 years ago
pinballpcb.com has the best replacement system 3-7 boards.
#20 2 years ago
Quoted from Matthew2015:
Don’t get the rottendog. Although I have 3 machines running them and they have been working for years with no problems there are a few glitches and missing speech. With no support now I wouldn’t recommend. I can 100% recommend pinballpcb sound/speech boards and their mpu is probably great too.
#21 2 years ago
okay , i may get the pinballpcb.com replacement boards . i will get the cpu board first and then get the driver board if the original one does not work.
is there any way to test if driver board is working without a working cpu board.?
$ 52.99
Pinball Shark
Shooter rods
1,150
New Lenox, IL
3,200 (OBO)
Sunbury, OH
$ 12.50
RoyGBev Pinball
Led
Playfields
Troxel Repair
Playfields
Tools
Pincoder Store
Tools
$ 27.95
KAHR.US Circuits
$ 130.00
KAHR.US Circuits
$ 11.00
$ 9.95
$ 69.99
Pinball Shark
Shooter rods
1,600 (OBO)
Webster, NY
$ 14.00
Other
This page was printed from https://pinside.com/pinball/forum/topic/flash-pinball-wont-boot- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
