(Topic ID: 241510)
Flash Gordon: Upper right flipper works intermittently
By BRW84
5 months ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 5 months ago by BRW84
#1 5 months ago
I've been working on chasing down the last few gremlins since I hardtopped my Flash Gordon , and I seem to have an issue with my upper right flipper. A friend and I rebuilt all the flippers a couple of weeks ago, and all was well until last weekend when my upper flipper started sticking in the up position occasionally. I figured out that the issue seemed to be with the solenoid bracket that holds the coil in place; it was putting a tiny amount of pressure on one side of the coil sleeve, which would cause the crank arm to get stuck when it entered the coil. I discovered that by very SLIGHTLY loosening the screws that hold down the solenoid bracket, it relieved that pressure and the crank arm stopped binding. About two games later, the upper flipper started flipping intermittently. It seems to activate about nine times out of ten, but the tenth time, it doesn't flip. Does anyone have any idea what I did? I've already cleaned the contacts on the switch that activates the flipper. It doesn't seem like slightly loosening those two screws would cause this new issue, so I'm wondering if it's a coincidence. Any help is appreciated, thanks!
#2 5 months ago
Check and make sure you have the correct spacing between the end of stroke switch.
#3 5 months ago
Quoted from McPin54:
I'll give that a shot tonight. It's certainly possible that I bent the EOS while messing around with that bracket. Can an improperly adjusted EOS cause a flipper to not activate at all? It seems like when I had a burnt-out EOS on my Gorgar, the flipper activated, it was just weak and didn't stay up.
#4 5 months ago
Quoted from BRW84:
The flipper switch on the right side should be a double switch (IIRC). In addition to checking the EOS switch on the upper flipper coil, check the right flipper switch to make sure it's gapped correctly. Also, check for broken or loose wires to the coil lugs.
Lastly, your solenoid brackets should be tight. If they are loose, over time, the vibrations will loosen the screw. I would check to see that your coil stop or bracket is not deformed. You should be able to tighten the screws holding the bracket down snug.
#5 5 months ago
fatpanda nailed it; one of the wires coming off the EOS switch had a loose connection on the coil lug. I'm back in business now. Thanks!
$ 149.95
Allteksystems
1,875
Denver, CO
$ 14.50
PinballElectronics.com
Displays
PinballSolutions.eu
