I realize this is a pretty common problem - strobe is not working - never has since I had the machine. Can anyone point to some basic tests I can do to troubleshoot what might be the problem. It hasnt worked for years - but figured why not take a look at it.
So I pulled the bracket off - the board and bulb are intact - wasnt stripped by the previous owner .
I replaced the 1A slow blow fuse - didnt appear to be bad but replaced anyways.
Any simple test to determine the repair strategy? Or do I just buy a replacement board/bulb and be done with it.
(Novice electrical work - I have a multi-meter and I am not afraid to use it - I have read that there is some serious shock hazzards in there so please help a fella out on anything with that to be ware of)
