(Topic ID: 65903)
Flash Gordon: Saviors of the Universe Club
By TheShameGovernor
10 years ago
  • 2,811 posts
  • 269 Pinsiders participating
  • Latest reply 9 days ago by zahner
  • Topic is favorited by 148 Pinsiders
There are 2,811 posts in this topic. You are on page 29 of 57.
#1401 3 years ago
"Anyway I've already dumped this PROM. Here's the contents:
"0000: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0010: FE FE FD FD FB FB F7 F7 EF EF DF DF BF BF 7F FF
The CRC32# of the file is: 7F18F0E4
It should be a simple matter of programming new Flash Gordon speech EPROMs and the sound EPROM on the Sounds Plus board. What problem are you having that you're looking at U9?"
My non-working Vocalizer had Xenon proms, and any that were readable were corrupted. No checksums matched any Xenon images. I was thinking that U9 could be corrupt as well.
Can somebody possibly make me a new U9 that I could buy?
I replaced CR1 through CR3, new C11 and C25, and installed a new 7805. I replaced a crummy looking U12 (74LS04). I rang out all the rom sockets, they are good. I tested the IDE socket (it's good) and bought a new ribbon cable. I don't have any 74LS30's, MC3417's, or MC1403's, so I ordered some.
I made new 7532 FG eproms for the vocalizer, and a u4 7532 for the sounds plus. I tested the roms in a working vocalizer & SP, and they worked great. I know the problem is in the vocalizer, as I repaired the SP and it works fine with my working Xenon vocalizer.
What should I be checking next? Thanks much for the help!
20200917_192031 (resized).jpg20200917_192031 (resized).jpg20200917_192148 (resized).jpg20200917_192148 (resized).jpg
#1402 3 years ago
Direct short to the 5 amp fuse at the power board F4
Have looked at all of the obvious spots but can't find
anything out of the ordinary
Whatever the root of the problem is, it happened
during normal game play. Machine lights up on the
playfield but the displays are blank.
Any suggestions?
#1403 3 years ago
Quoted from mkdud:
What are you getting out of the board? No sound, corrupt sound, something else?
Please open a tech help request in the early solid state tech sub-forum so we don't clog the club thread:
https://pinside.com/pinball/forum/forum/tech-early-80s-solid-state
#1404 3 years ago
Quoted from Robotworkshop:
If I'm not mistaken you can also tell by looking at J2 since the early board only seems to have a 6-pin connector there.
Was there a tech note from Bally to modify the early S&T boards in regards to that -5V? I have one of those early S&T boards that I'm working on now and can do any needed mods while here.
I made a mini piggyback board with the resistors and transistors and
reapplied it to the OEM Flash Gordon S&T. I copied EBD S&T schematics.
It Works; and I never had trouble with the Flash Gordon S&T sound board I have.
#1405 3 years ago
Has anyone had their "Shoot Again" not work? The light works in test mode but the lamp doesn't come on in gameplay ever and it we never kick my drained ball back. I've dug through tons of forums on here and most people have an issue with it staying on. Not me. Anyone have a fix?
#1406 3 years ago
Quoted from face4radio:
Extra Balls turned off??
#1407 3 years ago
I just had this same issue recently. It turned out to be a connector issue for me. I redid the pins and connectors on the MPU and SDB, and it fixed my problem.
Edit: I could have gone through each connector or pin to see which had the issue, but I decided to do them all instead. Also did the power board, but that was unrelated.
#1408 3 years ago
Extra Balls off was the culprit on mine.
I have developed a nasty ghost scoring issue on odd right flipper fires...pretty sure it's the saucer that is rewarding the points, based on the accompanying sound...but the switches appear fine and not firing due to vibration on the PF.
#1409 3 years ago
Here’s one I restored a number of years ago. I went with the darker yellow rather than gold on the cabinet stencil. I also used REGAL RED for the base.
87EA8946-4654-4D11-BBE2-B41FD4717439 (resized).jpeg87EA8946-4654-4D11-BBE2-B41FD4717439 (resized).jpeg
#1410 3 years ago
I assume when you ask if extra balls are off you are referring to self test 16 and 17? I tried every combination on those setting and it doesn't kick on. Is there another location for it?
#1411 3 years ago
"I made a mini piggyback board with the resistors and transistors and
It Works; and I never had trouble with the Flash Gordon S&T sound board I have."
Can you please show a picture of this daughterboard you made? Sounds like a good idea. Thanks, mk
#1412 3 years ago
Hi y'all. New FG owner here, pretty excited! I get pretty ocd with my games and want everything to work perfectly. The following give lights are always on, whether in attract mode or game. I suspect they are controlled lamps that should flicker in attract mode, and otherwise turn on and off, and I have some lamp drivers to replace. But wanted to check first. Can someone please confirm?
IMG_20200928_183938361~2 (resized).jpgIMG_20200928_183938361~2 (resized).jpgIMG_20200928_184045848~2 (resized).jpgIMG_20200928_184045848~2 (resized).jpg
#1413 3 years ago
Quoted from EvanDickson:
Hi y'all. New FG owner here, pretty excited! I get pretty ocd with my games and want everything to work perfectly. The following give lights are always on, whether in attract mode or game. I suspect they are controlled lamps that should flicker in attract mode, and otherwise turn on and off, and I have some lamp drivers to replace. But wanted to check first. Can someone please confirm?[quoted image][quoted image]
The blue collect bonus light definitely shouldn’t be stuck on. I think the others are on, though. I’ll check next time I turn it on.
#1414 3 years ago
Yes, the bottom two pop bumpers are always on (part of the GI string), as are the top left rollover lanes.
Your blue collect bonus light probably has a bad transistor on the light board. Check the light board schematics to find out which one it is and replace.
#1415 3 years ago
Is that Blue Bonus light a bulb or LED?? Looks almost like a LED from the pic, and you may be seeing ghosting.....
#1416 3 years ago
Quoted from Fytr:
Oh, and to confirm, the top pop bumper should flash on and off, and not be always on.
#1417 3 years ago
Followup question: Sometimes my displays are solid color. Sometimes they flicker/flash. I can't tell if this is a feature, or a gremlin. I suspect gremlin. Here's a vid of them being flashy (hope it doesn't mess people up that there's TAF music in the background).
Edit: I assume this is a gremlin not a feature, and I'll be doing all this stuff tomorrow:
Flickering Displays.
Flickering displays can often be attributed to cracked solder joints or a broken lead on a component. Here are some things to check:
Pin 36 on the display glass.
R21, R22, R29.
Q17.
U1 pin 13.
Often reflowing the solder joints on these components will fix the flickering problem. Also reflow ALL the header pin solder joints. These crack easily from plugging and unplugging the cable.
#1418 3 years ago
Quoted from AUKraut:
Yes, that is an LED, and there's no adapter kit for the lamp board. I'm thinking they might be anti-ghosting led - there are other LED in this one that seem to work great.
#1419 3 years ago
I asked about ordering the NB2 board and this is the response I got on 9/12/20:
"sorry for the moment I am out of stock + big work for the company move.
Normally available between one and two months.
Yes I already ship to the US.
NBII + shipping costs (with insurance and signature) = 270€
Best regards, stef"
$320 USD seems steep. Am I wrong?
Also, I am looking at pulling the sound files from the movie to map out the entire game myself. Does anyone know the format they need to be in? The website doesn't say.
I just spoke with Nicolas yesterday. He has them in stock. I ordered 2 more since I'm picking up a FG this weekend! The other will go in a Fathom that I will one day own.
#1420 3 years ago
Quoted from SeaLawyer:
I just spoke with Nicolas yesterday. He has them in stock. He said he hasn't been out of stock recently. Are you trying to order them from somewhere else? I ordered 2 more since I'm picking up a FG this weekend! The other will go in a Fathom that I will one day own.
#1421 3 years ago
any chance someone has a spare transparent plastic that is next to the inline target? Mine just broke and I am not ready to buy a full set...
thanks!
#1422 3 years ago
Quoted from hisokajp:
thanks!
Could you cut your own out of a sheet of Lexan from Home Depot? It's largely hidden underneath a regular plastic, isn't it?
#1423 3 years ago
Quoted from Nokoro:
i would definitely do it, i have the material and band saw BUT mine shattered in pieces... so I would a least need a scan if someone had one on hand?
#1424 3 years ago
Next time I have things apart, I’ll try to help you out. Someone doing a shop job might beat me to it. Unless it is easily accessible in which case I may have time this weekend . . . .
#1425 3 years ago
I'll scan my original this afternoon and post it for you........
#1426 3 years ago
#1427 3 years ago
Thanks all!
#1428 3 years ago
Here you go, JPEG at 300dpi with a ruler for good measure:
#1429 3 years ago
Here you go, JPEG at 300dpi with a ruler for good measure:[quoted image]
perfect, thanks a lot!
#1430 3 years ago
Can someone count the number of "wee woo" on startup of their working flash gordon? I'm sure mine only did it a few times when it was working, and now that it's not working I get 20 of them. Having trouble finding any info on the startup sequence sounds, and unsure if chasing that is a red herring or not.
#1431 3 years ago
They go by pretty quick, but 6 on mine...if I am counting them right.
#1432 3 years ago
Quoted from guitarded:
thank you, that means I'm not crazy. And I think it's reasonable to guess that the number of cycles is a helper to indicate what the issue with mine is, I just can't find any info in the manual / pinwiki / google about the startup sounds. But for now, at least I'm not crazy. Yet.
#1433 3 years ago
Just some info: My game makes different length/sequence of the start-up sound based on what mpu I have in it (OE, Altek, Weebly). It never impacted the game play, so I never looked into it any more.
#1434 3 years ago
Quoted from djblouw:
Interesting. The sound probably doesn't mean failed bootup because xxx then, it's probably something more like MPU not recognized (because failed bootup). I'm going to stop chasing the sound thing then and just do what I'm guessing my next step is, hoping it works.
#1435 3 years ago
Anyone have the wiring diagrams to the squawk and talk board available?
IPDB is missing those pages...they have the vocalized which is different?
I want to re-pin all the connections and I want to make sure wiring is done right.
I would loved color codes to pins I have to figure it out somehow.
Any help...
#1436 3 years ago
I see the wiring for the 15-pin connector going to the s&t is on the back box wiring diagram. Here's the portion of the diagram, and the color code chart.
IMG_20201023_001552.jpgIMG_20201023_001552.jpgIMG_20201023_001557(1).jpgIMG_20201023_001557(1).jpg
#1437 3 years ago
Quoted from frunch:
How do we get colors from that? I have a guess, but could use confirmation.
My guess is that I see J1, pin 1, leads to A4 (board) J4-4 (connector, pin) and A3 (board) J4-6 (connector pin). To the left of J1-1, is "23" which means wire color blue/yellow. Is that how it works?
#1438 3 years ago
See the below example:
#1439 3 years ago
Quoted from frunch:
Thanks again Quench....
#1440 3 years ago
Quench - do you happen to have all S&T info, mine appeared to have a vocalizer and I am rewiring it back to S&T so I need the plugs to the board itself.
Is there more than the 15 pin plug -
I have no reference from mine....I have to re-create it all.
#1441 3 years ago
Quoted from wamonkey:
Many people consider the Vocalizer to have clearer speech than the Squawk & Talk. If you have the Vocalizer setup, I'd probably leave it.
In any case, below is the Squawk & Talk connector info in my Flash Gordon manual.
Note: the Squawk and Talk connector has an extra G.I wire added at pin 7 - it's used to create a -5V power supply for the S&T speech chip. The other wires and placement are the same as the Vocalizer 15 pin connector.
The last picture is included because it has a small strobe connector table not included in the wiring schematic in the IPDB manual.
#1442 3 years ago
Quoted from Quench:
I had no sound board in mine when I got it so I could only get the regular squawk and talk board to replace it. So, I have to figure it out....
So, if I read what you are saying - there is only the one plug sent to the S&T and it is the 15 pin connector, no other plugs connected?
I wonder if I have to re-create the -5V from somewhere? I assume I can just tap into a light socket to get the 5volt on pin #7 if I have to.
Thanks - if you have a picture of the plugs and the S&T board mounted that would be great to see just to make sure I am doing it right.
My machine was a $300 box of parts so this is what you get when you do a higher end restore from random parts. But, my restore looks amazing and I am almost done. I have another pinside post on my restore if you haven't seen it -
https://pinside.com/pinball/forum/topic/flash-gordon-lacked-flash-and-gordon
#1443 3 years ago
Robotworkshop recently did mine. Very cool, knowledgeable and helpful guy. If you have a specific question, I'd reach out to him too.
#1444 3 years ago
Plus the speaker output connector...
located on the bottom far right.
Note: know which version S&T you have... Centaur is sightly deferent.
---- Some S&T 's have deferent components...
---- Best to use EBD S&T with FG snd roms.
#1445 3 years ago
Quoted from vec-tor:Plus the speaker output connector...
Revision D - will I have issues? I had no sound board in my game when I got it so this is what I could get.
#1446 3 years ago
Quoted from Fytr:
Any S&T board version will work fine with the correct roms and jumpers
#1447 3 years ago
For Flash Gordon, one of the chips you need is the U12 AY-3-8912 sound generator.
If you can, post a picture of the S&T sound board.
#1448 3 years ago
Is your backbox harness missing the 15 pin connector for the original sound board? Post a picture of the wiring so we understand what you're dealing with.
Xenon also uses the Sounds Plus and Vocalizer setup. This picture from the Xenon club thread shows the 15 pin connector already has the thick single orange G.I bus lamp wire at pin 7. So it's likely your harness already has that G.I wire there:
https://images.pinside.com/b/e4/55/be455540c55ed18ef3e7c29f5c8fdaad7ac181e4.jpg
Sorry, my game's in storage but here's a picture from this clubs image gallery:
https://images.pinside.com/0/8c/9d/08c9d131ac26626b3d7680f912786ad8c509c1e3.jpeg
Fantastic work!
You'll want to lower the flippers to align them as Bally designed otherwise the drop targets on each side will be harder to get good shots at. At rest, the Bally flipper bat tips should meet with the playfield alignment divots. Using the thinner Williams flipper bats you'll need to compensate a little.
#1449 3 years ago
Quoted from Quench:
Fantastic work!
You'll want to lower the flippers to align them as Bally designed otherwise the drop targets on each side will be harder to get good shots at. At rest, the Bally flipper bats tips should meet with the playfield alignment divots. Using the thinner Williams flipper bats you'll need to compensate a little.
I think I got the wires right....someone split the plug it appears so I was able to figure it out. I spent the most time working on repinning the solenoid driver board...that is a lot of pins. I think it should work.
Thanks for the advice on the flippers I will adjust those.
I am just dreading doing the displays that is about what is left to do. Remember this pin was boxes of parts and separated cabinet pieces so I am sure something will require work. I had no boards, no flipper assemblies, basically everything removed. But, the boards are new, re-capped or repaired. Only the sound board (recapped) and the flasher board repaired new bulb etc. are original.
As I install stuff I see stuff to fix, I want few or no issues when it is done so I re-pin, zip tie , or adjust stuff prior. I am getting better on fixing stuff the more machines I restore. The help you guys give just make it faster easier, I don’t have to spend hours looking for stuff. I don’t know why IPDB is missing Squawk and Talk pages....
#1450 3 years ago
I will post a pic of my board...
You guys can check my work....
The wiring looks all the same...
$ 8.00
Third Coast Pinball
$ 5.00
Hardware
Volcano Pinball
$ 119.95
Allteksystems
Retro Electro Designs
Playfield - Plastics
$ 99.00
Hardware
Volcano Pinball
$ 18.95
$ 29.00
RoyGBev Pinball
Hardware
Volcano Pinball
$ 100.00
Volcano Pinball
7,995 (OBO)
$ 22.95
$ 29.00
RoyGBev Pinball
$ 7.00
5,000 (OBO)
Houston, TX
Berkeley Springs, WV
Troxel Repair
$ 69.00
Pinball Pimp
$ 299.95
Pin Stadium Pinball Mods
$ 179.00
This page was printed from https://pinside.com/pinball/forum/topic/flash-gordon-saviors-of-the-universe-club/page/29 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
