New! Dark mode!
(Topic ID: 273084)
Flash Gordon saucer launching
By Grangeomatic
4 months ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 4 months ago by jj44114
    #1 4 months ago
    Just put a hardtop on this Flash Gordon. All is going well, but the saucer kicks out really strong now. When it goes down, it gets airborne and hits off the pop bumper cap, then sometimes bounces right back into the saucer. I can see the pop cap breaking over time. When it goes up it slaps the glass, hits off the top by the rollovers and usually bounces back into the saucer again.
    Pretty sure that's not how it's supposed to work.
    Any suggestions on how to reduce the power of that kickout?
    Thanks,
    Jeff
    #2 4 months ago
    Check that the correct coils are installed. I just did a FG hardtop too. The seller of the original game replaced the up coil I think, with a kicker coil. Wayyy too hard, hit the glass every time. He assured me the coil would “break in” over time....mmmk. Anyhow, confirm the coils are correct first I’d say. Then look at the coil stops, armatures and resting tabs. Post a pic of the mech.
    #3 4 months ago
    Quoted from Grangeomatic:
    Thanks,
    Jeff
    Sounds like you have it 180 degrees out of phase, i.e. you got the orientation for it shooting into the upper playfield shooting to the lower playfield (and vice versa). Turn the whole assembly by 180 degrees.
    #4 4 months ago
    Quoted from AUKraut:
    I think we have a winner! There's 2 different coils installed on that mech, one is considerably stronger than the other--the stronger coil is to send the ball to the upper pf, and the other one is weaker since it's sending the ball down the pf (which requires a lot less oomph)
    #5 4 months ago
    I just looked at my tear down pics again, and that is correct, 2 different coils. I didn’t realize that. I’ll be checking my orientation tomorrow!
    I’ll report back either way.
    #6 4 months ago
    I checked out the machine this morning and found that it's still mounted the way it was originally. I never unsoldered this mech, and up is still up, down is still down, if you get my meaning.
    Also, the up coil is a 27-1300 coil, while the down coil is a 29-2100 coil, so it seems it's still "strong up, weak down".
    I'll check the manual and see if those coils are correct.
    #7 4 months ago
    Did you have it long before you put on the hardtop? If not don't assume that a previous owner didn't spin it around either or mix up the coils...
    #8 4 months ago
    Mine was doing the same thing even with the coils in the right position. Fixed it by bending the metal tabs in the saucer inward so the ball sits a bit higher. Gotta play with tabs to get it just right.
    $ 200.00
    Professor Pinball
    $ 299.99
    Hookedonpinball.com
    $ 52.00
    RGP Models
    $ 799.00
    The MOD Couple
    $ 24.95
    $ 269.00
    $ 69.99
    $ 79.95
    pinballmod
    $ 6.00
    German-Pinball-Modular
    $ 99.00
    $ 69.95
    Hookedonpinball.com
    Professor Pinball
    $ 214.99
    $ 18.95
    $ 40.99
    Lee's Parts
    $ 29.99
    Bent Mods
    $ 14.95
    $ 137.00
    $ 49.95
    pinballmod
    $ 48.00
    $ 7.00
    APB Enterprises
    $ 18.99
    Playfield - Plastics
