Cabinet stencils. My first time using Pinball Pimp stencils, and absolutely I would use them again. I had received them as a Christmas gift, so they had aged a bit while in the shipping tube, but still they were sticky and no issues. It's not recommended to wait as long as I did to open & use them, but I just couldn't get to this project. Anyway, thumbs up.
Lots of folks have done threads on using these stencils for painting the cabinets, so I'll focus on the things that were a little different for me. Rather than using cardboard or Styrofoam as suggested, I had some scrap wood a quickly made up a wooden block to close up the coin door opening. This helps to make the surface flat so the stencil goes on easier. Pocket holes were used to secure the panel in the coin door opening. I've saved this for re-use on future projects.
It had been two days since I finished spraying red. I was fired up, and it's time for stencils!
Black is the first color that goes on. I applied all (5) stencils for black, and sprayed them all.
Oh crap!
Lessons learned:
1) A light coat, wait 3-8 minutes depending, then another light coat. If the paint gets too thick, it's bad.
2) Only do 1 or 2 panels at a time. The idea is to peel away the stencil while the paint is still a little tacky - so the line is a clean break. You have a finite window of time where the dryness is just right. With all the details of these backbox stencils, if you run into trouble, which I did, it may take longer to peel off the stencil than you think. And at that point, the others were too dry.
3) Use the correct paint or at least test the paint for stenciling qualities first. I totally suspect that because of the primer additive of the "2X" paint, it dries faster and also seemed hold together and tear/peel instead of break cleanly when removing the stencil. I think I saw somewhere that I should have used the normal can - similar to the can of Regal Red that is shown above - instead of the "2X" version in black.
... Or maybe it was the gloss? ... Or maybe I should have let it dry completely??
Here are pictures of before then after the black stencils were used. I don't have enough pictures. There was a lot going on at the time... Notice the peeling along the edges of the black.
