Williams Flash. Serial No 375985, Built 1979. Early system 6 cpu. Replaced large filter cap on backbox floor & minor switches etc. in the past. Working, smelled electronic burning & turned off. On switch on only GI and Sound. Nothing else. Have manuals and checked power supply voltages, cpu test points, Diodes D7/8, fuses, rectifiers, cpu test LEDs. All nominal except TP4 at 0 VDC and F2 (replaced). Scores, attract mode, flippers, solenoids do not work. Does not seem to reset. Have more detailed test results if required. Any suggestions?
