Quoted from GPS:Hello Fellas
Ok. I understand the process and how to do it, I think. But in the event that there are graphics attached to the bottom of the ramp for instance, I assume those have to come off prior to the polishing. Has anyone had any experience here? Assuming if the graphics are not avail, than there is no flame polishing. Thanks in advance
G
You really don’t need to remove decals if they are under the ramp, as most are. But if they are on top, and the ball rolls over them, Absolutely definitely 100% remove decals (I assume that’s what you mean by graphics?), as they will melt into the ramp when you try to polish.
Flame polishing needs to move quickly on the top, where the balls roll on, and not heat up the plastic very much at all. If it’s getting even -warm- you may be overdoing it. So the (underneath) decals will be fine.
I also flame polish my plastics sometimes - you should Practice on a junk piece of ramp or a
Plastic to get the hang of it.
