I'm at the point in my restoration of Flying Carpet where I'm putting the end touches on the playfield. One of the issues with this particular machine are that all of the lettered inserts are warped. I was wondering if anyone has any suggestions outside of what is already available on Clay's site? I've had mixed results with crazy glue in the past and don't think these are readily available as repros.
The other issue I'm having is with the #1 ball lamp on that machine. I replaced the socket, and am still having issues with flickering. Any ideas on a fix for this? None of the other lights in that chain flicker, so I'm not sure why I'm having an issue just on that 1 socket and not the other 5 in that chain as they are all part of the same board and the electrical wire is securely fixed to the base with solder. I've already been over the connector, bakelite, and everything is as it should be and clean. I've replaced the socket itself 2 times and keep getting the same annoying dimming/flickering (like you get when there is a loose bakelite insert).
