I never recommend people using fingers, flat end screwdrivers, or needle nose pliers for micro switch leaf adjustments if you want a clean adjustment with no kinking or potential breakage.
It is harder to control the preciseness of the adjustment as well, if you are not experienced.
If person wants to use their fingers, that is their choice.
Once you own the tools you have them forever, they are not that expensive, and these tools do not normally break under use, unless extremely misused.
I use a full set for every type of possible angle.
You can even make your own in a pinch with a notched popsicle stick or small piece of wooden dowel with a hand file.
I had to do that a couple of times for owners, if I did not have my full tools.
It is still better than using fingers.
Although clipping a diode lead and testing it independently (while not under any electrical load) is usually accurate, it is not 100%.
Failures still do occur while under operation.
If there was too much solder used which affects the actual testing result on the remaining soldered end of the micro switch, or could effect the actual operation of the diode when the switch is activated.
"Old solder" (greyish, corroded, or "carmelized") that is on game's microswitches is also a culprit of increased electrical resistance, and can result in switch failure, although nothing is wrong.
The same thing applies for old style GI socket bulbs and wiring.
Literally you can polish it in a second with a dremel wire brush, and magically the switch starts working again.
One of the most common early "crib deaths" of diodes is caused by the diode being overheated during initial soldering without use of a heat sink (common during factory installation) or the diode was directly touched by the soldering iron during installation.
This is why I replace both at the same time, although I do always test the diode beforehand prior to installation.
I think I have only had a couple? diodes fail prematurely when replaced simultaneously with a microswitch in nearly 30 years.
It is a simple piece of mind, to not go back and have to do it again.
