Good Afternoon All,
Game worked fine yesterday, today it doesn't want to work fine. Game boots up without any credit dot.
Tracked down that the opto's are not registering under a switch test (Both flippers and Reel optos). Reset connectors on opto board, CPU board and Driver board. Getting 5.0 at TP2, 12.0 at TP3 TP6 73.2. Flippers do work under solenoid test. Was thinking bad opto board so pulled opto board from Indy and same result so its not a bad opto board. Checked reel motor and it does move when power provided by a battery. Continuity on 12V grey/yellow wire from opto board connection (J1) to driver board (J118). Did pull all fuses and all are fine.
Driver board Issue? Not sure where to head from here. If you have any ideas please let me know.
Thank you,
Loren
