(Topic ID: 227186)
Fish Tales Wont Start Game
By ChicagoPinReplay
  • 13 posts
  • 7 Pinsiders participating
  • Latest reply 3 years ago by ChicagoPinReplay
#1 3 years ago
Hello everyone,
I just picked up a project Fish Tales that was being tossed in the garbage. It has been folded up for the past 10 years in storage and the batteries which expired in 1999 were still in it. The holder was a bit corroded but nothing terrible and a few of the components had a bit of acid creep but not nearly as bad as I have seen in the past. It cleaned up very easily and I installed a remote holder.
Anyway when I booted the game up it of course wanted me to go into the diagnostic report. I opened the coin door and none of the diagnostic switches worked nor the coin switches. After looking for shorts I pressed the diagnostic enter switch again and the game freaked out and start adding credits and cranking the volume up and down on it's own. After pressing it again it briefly it went into the settings menu for a split second but then set the volume to zero and went back into attract mode.
With max credits added unintentionally I tried to start a game and nothing happened. So back to the coin door I went and this time around every button inside the coin door now added credits including the volume buttons. The odd thing is that sometimes the buttons respond (improperly) by adding credits and sometimes they will go completely dead. The coin switches will sometimes add credits too but only when the diagnostic switches are registering credits as well. Once in a blue moon pressing enter will go into the menus but shortly after it moves the volume up and down on it's own and then starts adding credits again for a bit.
Aside from looking for shorts I saw that the coin door switches are not part of the matrix but on a dedicated circuit. J1 and J3 on the coin door interface board connect to J205 on the CPU which are controlled by U16 and U17? I'm not sure if I'm correct there.
Pardon my ignorance but I also noticed the coin door lights go on and off with the GI in attract mode and that when the game is flipped on for the first time it appears to go through a brief ball search everytime for a few seconds. The kick out holes actuate one and the reel mechanism goes through a few cycles. I am not sure if this is normal or not for this title. All 3 balls are in the trough. Sorry for the long winded post but I did not know how to briefly describe what was going on. Thanks in advance!
#2 3 years ago
Battery damage on your CPU ?
#3 3 years ago
Quoted from LTG:
Yep, I had a Fishtales doing the same thing, I noticed there was battery alkaline damage on the chips below.
#4 3 years ago
I agree. Even though it looks clean it has probably done some damage. My Getaway was crazy like that from acid damage.
I got a steal on my FT from an op who didn’t want to put the game in storage coming off route but free.... what an awesome score man. Congrats!!!!
#5 3 years ago
Agreed with everyone else. The cabinet/coin door switches enter the CPU right below the batteries. Most likely the alkaline has plagued the connector and other components. I had a Black Rose with the same issue. I unfortunately had to drop a new CPU in and redo the connectors, problem solved.
#6 3 years ago
Quoted from kvan99:
Any idea which components control the coin door switches? I'm seeing U16 and U17. Just trying to gauge what I may need to replace.
#7 3 years ago
Quoted from ChicagoPinReplay:
Start with U16 and U20 but inspect the rest and the one next to it U119, you can see the corrosion most times on the leg, and you can tell which one is damaged visually. Have you done IC chip replacements before? It's tricky, you would be better off to cut the legs off and remove them one by one with a tweezer or a small plier. Then use a solder sucker to clean up the remaining solder, lastly I use a toothpick to clean the holes. Then you want a socket installed before inserting a new chip.
https://pinballrehab.com/1-articles/solid-state-repair/board-rework-test/210-repairing-alkaline-battery-damage
#8 3 years ago
I would also chech the connectors on the bottom of the CPU as I had one that had acid in the connectors.
#9 3 years ago
Quoted from kvan99:
Well I replaced U16 and U17 and it will start a game now. Unfortunately the coin door is still dead and there are a few switches out now that I can get a game going. Progress but obviously the acid damage did it's due diligence. I'm going to look at u20 and u19 next. Are replacement boards available? Should I try to keep diagnosing this one?
#10 3 years ago
Yes.
No idea. You might work through it all. You might not fix it. It might not last. Your call.
#11 3 years ago
Quoted from LTG:
Yes.
Yes, as the experts say, if you don't cleanup the corrosion physically (sanding, bead blasting etc) it will keep eating other components. The replacement board is a good shortcut to get the game up and running.
#12 3 years ago
I contacted the seller about purchasing this but you had already beat me to it. What condition was the playfield in?
#13 3 years ago
Quoted from davijc02:
Filthy but zero wear. The further I go the more I find the acid has destroyed. Many of the traces have been destroyed. I'm probably going to just replace the CPU with a new one. Thanks for the help everyone.
PinSound
£ 50.00
Cabinet Parts
PinballToys
$ 349.95
Pin Stadium Pinball Mods
