as above. i get 52 volts ac coming in from the plug. but when i test at TP6 i am getting 74 volts. I replaced the bridge rectifier with no change. I am guessing the problem is with the capacitor c8 (100 uf/150volts) because that is the only other component in the schematics beside the resistor( which measures appropriate at 10k) that is there. But i thought capacitors did not affect voltage? If i dont do anything will this start blowing coils or flashers?
